18 minutes ago, Thomastenn said:
am looking into putting an ai engine harness and e my
I read this as you intend on putting an AI harness and ECM on your AC engine. If I'm correct there's no way that will work. The two engines are different internally. There are some real ASET experts on here that will clarify though. If I am wrong I guess you would just need to find an AI ECM from a truck that has the same series Allison transmission you have.....
https://www.bigmacktrucks.com/topic/69463-aset-ac-to-ai/#findComment-493961
ASET C is a totaly different harness. 3 plugs on the EECU, compared to 2 plugs on the ASET I..  cam is different, turbo, exh. manifold, EGR cooler, intake manifold, water pump, im sure I forgot some other differences..  i hope i understood the question correctly, seems like a 'typo' in the original post... jojo
https://www.bigmacktrucks.com/topic/69463-aset-ac-to-ai/#findComment-494027
He’s getting a new EECU, Turbo, Manifold, and harness. I’d imagine he’s doing a delete on the egr as well. I believe the fan is different on those if we want to talk about differences
Edited by Onyx610
https://www.bigmacktrucks.com/topic/69463-aset-ac-to-ai/#findComment-494028
