i stopped buying mowers a few years ago after the introduction of "garbage gas"
the ethanol crap eats carbs. i could not get 1 full year out of a carb, and only two years before the deck rotted out.
three years ago i bought a kobalt 80 volt cordless string trimmer and just use that for the whole yard. takes about the same amount of time as the mower did.
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-495518
I broke down and bought this mower five years ago and never looked back,built to near commercial specs,installed the mulching kit and haven’t raked a leaf since and let me tell you I have a chit load of leaves every fall,it just pulverize them,awesome machine..
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-495521
I know how you feel Rebel,  those are the days were it is best for me to just stop trying to fix anything,,,,  I laughed at youre expense as well..  Probably just jinxed myself, I'm about to do some brake work on my Old '48 International. BTW,  I have 3 Harbor Frieght predator engines and they all run great,,  I have a small one that sat for 2 years, I puled it once with the choke on and it fired right up,,  I even had a witness, he couldnt beleive it either..  I hope you enjoy a hot meal.... :)  Jojo
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-495525
10 hours ago, 1958 F.W.D. said:
www.pure-gas.org
There are a couple stations around here on that list...and I use them exclusively for my motorcycles. Unfortunately, it's only "premium" offered w/o the corn additive, and that $#!+ is expensive. Bikes are high compression & need the high octane. Mowers, not so much. Push mower could probably be replaced for the difference in cost over the 7 or 8 years it's been since I bought it...wasn't a very expensive mower to begin with, & it was on clearance as a discontinued previous year's model.
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-495626
I run with the pre-mixed 100% dinosaur from the hardware store in my small 2 stroke engines.  I only go through a gallon or 2 a year so it's a small premium to pay to know that they will start every time I need them.  For the lawn tractor I only buy 2 gallons at a time and dose it up with a stabilizer.  Seems to do the trick so far.
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-495631
I  use the additive myself it works real well gasoline last a long time I am the same way I don’t have a large area 2 gallon jug is usually all I need for all my machines for the whole season and that includes my five horse Briggs & Stratton air compressor.. bob
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-495645
i mix the crap they call gas here in joisey with double dose of marine stabil, and double dose of regular stabil. 5 gallon can will last me close to 2 years and still be good. if left untreated it will be bad in under 4 months. i have to run the gas tank dry on the plow truck, otherwise it will not start after 4 months if untreated gas in in it.
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-495649
No it’s not worth a shit I bought a car years ago that sat for 16 years with a full tank of regular leaded gasoline would you believe that car would skid the tires when I gas it after I ran  that tank out car didn’t have anywhere near the power that 16 year old gasoline did to tell you the truth I didn’t even think it was going to run at all with that old gas instead it was the other way around the shit was like rocket fuel… bob
  • Haha 1
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-495650
I can get 87 or 89 Octane corn free around here, I think I saw earlier today it was 4.71 a gallon. It's all I will run in my small engines, the smaller the engine (blower or trimmer) the better it runs on corn free. And around the end of September I start to fill the F.W.D. exclusively with corn free so that by the time I park it for winter hibernation at the end of October, all it has in the tank is corn free. Don't wish to have to rebuild that carb again.
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-495686
I used to use StaBil- well, actually I still do, but I read that Sea Foam also keeps gas from "going bad" so I put that in in too. I fill two cans a year with ethanol free gas, one for the lawn mower, a push mower, and one that I mix for my 2 cycle engines- chain saw, leaf blower, and weed eater. I put both Sta Bil and Sea Foam in both of them.
I used to put a can of Sea Foam in that 4 cylinder Ranger I used to have periodically and you could definitely tell the difference.
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-495952
1 hour ago, mowerman said:
The way you set it up it looks like he is pulling you ha ha thanks for sharing
LOL...with the reliability of this mower, he just might be...😜🤦‍♂️
https://www.bigmacktrucks.com/topic/69554-dadgum-mower/#findComment-496021
