How long of an idle does it do this? Bump the idle up when idling for longer periods. See if that clears it up. Could be “wet stacking”
Edited by Onyx610
Onyx610 if im sitting at idle like for 30 20 minutes and when i start moving maybe and at around fourth gear it does clear up and after that until sit for around the same time it does again but not every I notice this like from 2 months ago and it didn't happen Avery day.i assume this is relate to the oil leak from the fuel injector o ring I was telling Joey Mack before oil was into the cylinder.
I guess a compression test may be in order, or can you keep running because it's a minor issue,,, sorry bud,,,   one of us needs to be there with you  to see whats up...   👍  jojo
yes I do,  but you need special tools..  check out freedom racing.com/ tillman tool.com/ monaco tool.com////   The tools are U.S. ish made, but do a good job..  I have neary $10,000.00 worth...   jojo
