- 0
2003 Mack CX 613 wastegate derate issues
Question
Walkyrie_Engineering
been having this problem for quite some time now, I keep getting a 4-5 flash code and the engine seems to lose power (naturally right before the crest of a hill or right when you most need the boost) I replaced the turbo, so i know it's not a mechanical issue, and checked the airline going from the manifold to the wastegate and no apparent leaks and pushing air through the line actuates the wastegate. so at this point I'm not sure where else to go manifold pressure gauge reads boost pressure is it possible that the boost pressure sensor may be faulty reading a higher psi than is actually there?
https://www.bigmacktrucks.com/topic/69863-2003-mack-cx-613-wastegate-derate-issues/Share on other sites
26 answers to this question
