bottom rad should have a drain either on the bottom rad tube or the rad likley the tube! You only need to drain 5 or so gallons of coolant to do this! I f you haven't changed the coolant in a while wouldn't hurt to change it All ! install new 50 /50 coolant! Probably 14 gals or so!
Edited by fjh
https://www.bigmacktrucks.com/topic/69923-thermostat-change-e7/#findComment-499717
There's a fitting on the bottom radiator hose.  Or it's on the bottom or left side of the radiator.  If you don't care about making a mess, you can pull the compressor hose, but those tend to be very stiff.  If you use the proper drain into a clean bucket, then you can re use the coolant.
https://www.bigmacktrucks.com/topic/69923-thermostat-change-e7/#findComment-499749
