any chance the pedal is worn out? the TPS, can cause this.  does it do it at the same spot? of course there could be a dozen other issues, im just tossing out 1..  Jojo
https://www.bigmacktrucks.com/topic/69953-1998-mack-trident/#findComment-500348
2 hours ago, Will said:
Could be, haven’t looked there. Basically if you hold the pedal flat it’s doing it, not getting enough fuel or something around those lines. 3-4 code is coming up but have replaced both engine position sensors and still doing it.
I think your on the right track ! I would check fuel filters then check the fuel pressure should have a minmum 60 80  psi under load
https://www.bigmacktrucks.com/topic/69953-1998-mack-trident/#findComment-500359
there are 2 ports on the right rear of the block, right in line with the fuel inlet and outlet.  it take's a 1/4" ratchet to remove the plug..  the top one is fuel in and the bottom one is fuel out..   I just did this a few hours ago on an RD..  1/4" NPT threads..  just hook to one of them..  "F" is right about fuel pressure..   My truck was putting fuel into the crank case, pump tested good,  I had 125 PSI fuel pressure..  I re-ringed all 6 EUP's and have a 60 PSI regulator coming in the morning..   Good luck sir...   Jojo
https://www.bigmacktrucks.com/topic/69953-1998-mack-trident/#findComment-500401
Just for kicks... 3-4 is engine postion...  'cam sensor'...   see if there is a teardrop shim behind the sensor... if so, put it in your pocket. and run the truck again to see if the issue goes away..  jojo
https://www.bigmacktrucks.com/topic/69953-1998-mack-trident/#findComment-500418
