Hi guy's..  So I was given the task of finding out how the oil level rose up due to diesel in the crankcase..   I got this job after a few other issues occurred.  I learned that it was smoking heavy, so they replaced the injectors.  Well I found out yesterday , when I pulled #6 injector due to low temp on the cyl. by 50 degrees, it was rusted and not new...  and a newbie was doing the repairs with no real guidance.. and he doesnt speak English..  I asked about the EUP's?  The owner said #3 broke a bolt and moved..  new bolts but no new orings..  Ok, so I go back to that EUP, pull it and re-ring it..  They run the truck for part of the day, and oil level is 1" over full.  So they give it back to me...  I re-ring the other 6 EUP's and then check fuel pressure..  I did not check fuel pressure first, for my own reason's..   When I check fuel pressure, it is 125 PSI..  Today I changed the oil and filters, set the level to the full line, and put a new 60 PSI regulator on it..  I ran the engine and fuel pressure was almost 70 PSI..  No sweat..  So tomorrow they will run the truck to see how it does.  I couldnt drive it for an hour, because I am building an ASET-C as well, and they didnt want me riding around...  :) .  So my question is...  Barring a major issue like a crack somewhere..  How else could the crankcase get diesel contamination..    I figured the high fuel pressure was pushing it passed the lower EUP o-rings..  I don't get stumped often, but on this one, because 2 people were on it and one cant speak english..  I don't have the whole story..   I pulled the valve covers and ran the engine and watched the injector plugs for leaks and they were good.  ok.. I will stop here and wait for some other ideas...  Thanks guy's,  Jojo
https://www.bigmacktrucks.com/topic/69967-01-rd-688s-fuel-in-the-oil/
yep,  and the pump is good, EUP's are re-ringed, and the EUP bores were good, as far as injector caps.. no leaks, I ran the engine up to temp with the valve covers off, and saw no fuel bubbling around the caps...  I hope the new regulator that dropped fuel pressure from 125 PSI to 70 PSI, is the fix..   This engine is not smoking, it was just raising the oil level with diesel..  We'll see.. I will keep posting..  thank you for responding... jojo
Joe if the engine is NOT CCR the Injector top Oring on the injector can let fuel into the heads Seen this happen as noted ! You may not see it unless you pull the caps! Also running that high of fuel pressure may have compromised The fuel pump Seal new or old! Just sayin!
Thanks 'F'..   I pulled the fuel pump and put shop air to the inlet and capped the outlet.  i adjusted the shop air down..  there was no air leak. so I figured it is good..  I actually did this last week on an ASET-C, and the pump seal bled air like a stuck pig..  i took that pump apart to find the impellor was grinding into the housing.. That engine got 'washed'.  I am currently rebuilding it..   Same customer, 3 different units put fuel in the crankcase in 2 weeks..   jojo
Well, today I pressure tested the fuel galleries and there was no 'leak down' . then I pressure tested the return ports in the heads, no (leak down)..  I pulled the fuel lift pump off again and tested it too..  no leaks. I pulled the injectors just because,,,,  and there was a little rust in the #6 injector bore, and that cylinder was also running 50 degrees cooler than the other 5.  The owner told me today that the issue started shortly after his mechanic replaced the injectors due to heavy smoke coming out of the stack. So I pulled the heads,  i will continue tomorrow.  It's funny how they had 2 trucks and an excavator, get diesel in the oil, in a 2  month period..  Dumb luck I guess..  I welcome any thoughts/ opinion's/ and guidance... I am still scratching my head on this one..  :) Jojo
Buddy My thought here is that transfer pump ! bench testing is not a reliable test in my mind ! As the engine is not tuning the shaft ,Static the shaft may not leak but turning it  and any gear vibration may change your scenario it may leak ! Just sayin! Ya the fact that three machines in a week is suspicious !but at this point I can't connect any dots myself! Hope fully you fine some cracks in the heads but its a long shot! That said was the bore on number 6 injector pitted from rust and not sealing!?
Expand
Also to add to the leaking shaft, temp change…
Edited by Onyx610
Spelling
the injector bore looked good..  I was able to clean it up with ease..   #6 was running 50 degrees cooler than the other 5 and they were within 10 degrees of each other.  As far as the lift pump goes, I can understand youre concern. I did rotate the pump and push and pull on the gear and try to move it sideways, sprayed with windex and not 1 bubble... When I got the heads off.  the #6 liner was really shiny, no cross hatching left.. I didnt go back today because of other road calls to go to. I hope I find some cracks too.. yes, its a long shot. The owner, told me an hour ago, to rebuild it.... he's done messing around..  I WILL replace the lift pump!!!..  Thank you for your input,  its always welcomed..  jojo
Well, no info on what caused the fuel in the oil.  I inspected the cam while I was in there and the #1 exh. lobe has a chip in the lift..  So I am definately re-building this one too..   Be careful what you wish for....   I needed some work a couple weeks ago, and now I have 1 customer with 3 engines that need re-building....   An ASET-C, which I loaded pistons and liners into yesterday, waiting on the lifters.. An E-tech,  and an E-7 V-Mac II..  I still have one of his ENDT 673's in my shop, and another 3 cyl. John Deere to build..  🙄  :) Sorry I dont have an answer as to how the fuel got into the crankcase.. If I do find the reason, I will post it..  thanks guys, jojo
