Well almsot 3 months back to work and things are going pretty good.
I have been trying to figure out what the easiest air ride swap  I can use that will accept 50k axles and 5.02 gears.
I don't have the time to go to the salvage yard and measure rear cuts and searching the internet isn't yielding  much.
I have been loading heavy to the rear and keeping the drives around 36-39k but its putting 60-70k on the trailer. My permit wants 23k per drive for 46k and 18k per trailer axle. (I know seems odd to me too.) that's why i want a 50k set for the rears
Any thoughts would really help.
Edited by Tinman22
https://www.bigmacktrucks.com/topic/70112-air-ride-conversion/
  • 5 weeks later...
I just replaced the 'Z' springs on a CXN last week..  Repairing that suspension is easy on your back, but not so easy on your wallet...  definately keep the u-bolts tight..  during a walk around, you can hit them with a hammer... if they ring out, they are tight,  if they 'thud' they are loose..  just a quick way to stay on top of them ... jojo
https://www.bigmacktrucks.com/topic/70112-air-ride-conversion/#findComment-506044
Our V8 Valueliner was built with the Neway's and is rated at 80 tons payload, worked to pull heavy low loader trailers. Our B 75 has same Neway - which came off a Canadian V8 Superliner that was a cattle truck, after all the cattle piss for many years the Neway steel was very good after we sand blasted all the frame.
https://www.bigmacktrucks.com/topic/70112-air-ride-conversion/#findComment-506754
I believe that is a 38,000# set up with the 8 hole axles.. You got a hell of a deal there..  there are sooo many useable parts..  awesome !!!
https://www.bigmacktrucks.com/topic/70112-air-ride-conversion/#findComment-518542
If the budd hubs are close in year range they should..   I know you know, but when you strip them off slide one on the new spindle and torque it down..  I bet it fits...  I have converted a handfull of them and have had ease in getting bearings and wheel seals..   I wouldnt be surprised if they are the same.. jojo
https://www.bigmacktrucks.com/topic/70112-air-ride-conversion/#findComment-518545
They are both 85 r models. Im not sure about a direct swap though. my current set are an ss34 in the rear and an ss38 front factory original.
Everything I looked at says 34's have a bigger bearing than the 38's but funny enough mine are some weird bearing in between big and small.
If it were easy everybody would do it. Heck i'm still hunting a front crossmember to put an e7 in it! I can't even find a picture of one.
https://www.bigmacktrucks.com/topic/70112-air-ride-conversion/#findComment-518547
I get it... I was grabbing at optomistic straws...  anyway,,  it's not hard to do..  Now I wish I wrote down all the part numbers when I did a B-model and 3 RW's..  a year and a half ago..   Many others here can probably tell you what you need better than me, at this point..  jojo
https://www.bigmacktrucks.com/topic/70112-air-ride-conversion/#findComment-518550
You won't need a front cross member, just the E7 motor mount. If you are able to find a parts man that gives a shit they can look up someone's vin from an r with an E7
https://www.bigmacktrucks.com/topic/70112-air-ride-conversion/#findComment-518789
here are 2 RD vin.'s .   RD 690 S/ 023858....   RD 690 S/  023859..  '96 model year..   I took care of these 2 trucks for 8 years..  Good luck ,,,  Jojo
MERRY   KWANZAHANAMAS...  🍻
https://www.bigmacktrucks.com/topic/70112-air-ride-conversion/#findComment-518791
  • 3 weeks later...
On 12/24/2022 at 2:59 PM, Sk1981 said:
Have 1981 super Liner with the neway air ride. If the axle are 8 hole they are 38000#. Bags look taller in picture then mine do. Never could figure out how heavy axles I have. Thanks
We have the same Neway air ride, when I ordered new airbags  I was informed the airbags are 1 standard size for this Neway airbag suspension.
https://www.bigmacktrucks.com/topic/70112-air-ride-conversion/#findComment-520994
