- 0
Timing E6
Question
Macktruckman
I had a 285 tip turbine and removed the tip turbine setup and went to a regular intake and installed a charge cooler in front of the radiator. Took the pump and injectors (Robert Bosch) to pump shop and had rebuilt and recalibrated to E6315 specs plus 15%.
bought a new holset hx50.
now I don’t know what to set the pump timing at for best results. I have looked and looked here and elsewhere. Does anyone know what I should set it at?
engine is around a 1980 2 valve. Timing marks on damper and pointer on the front cover
thank you in advance
josh
https://www.bigmacktrucks.com/topic/70159-timing-e6/Share on other sites
2 answers to this question
