On 8/12/2022 at 6:43 PM, Angelo said:
Can someone explain to me what the difference is between the 707a,707b,707c . I have lead on water pump for my 52 L model but it’s out of 707c and I’m not sure if it’s all the same. Thanks
The 707a & 707b are pretty interchangeable across the board, just a few minor differences of which I can’t remember. The 707c sort of has the head turned around so the exhaust manifold is on the other side. I don’t know what other changes there might be associated with that.
Who needs a back yard when you could have a :mack1: Yard?!
  • 3 months later...
A man in Harrisburg PA by the name of Calvin Little has about 15 707 Engines not sure whether he has any A’s but he does have B’s and C’s and his number is 717-566-8973 hope he can help you he has helped me on my 70 Mack firetruck
