  On 8/17/2022 at 12:24 AM, Dirtymilkman said:
Would there be a torque switch on the transmission on this one?
Expand
The wires will be there and  if they are shorted to each other, the computer would think it was in low range and hold back on fuel! No Codes Nothing ! cause all is normal in the Brain It would see nothing wrong with the situation!
visual inspection..  keep it simple.. too many times guys want to grab the laptop,  when there may just be a broken wire...   visual inspection.....   jojo
be gentle with the EUP wire screws..  they break easy...  2 turns loose is enough to slide the wire off..  light torque when you put them back on..  5mm 1/4' drive socket..  good luck bud...  jojo
