Most likely bad earth, check/ clean/ tighten connections from block, starter, chassis and isolator if you have one. Make sure you don't have a dud battery in the mix, charge and test them individually. Check armature housing on starter for loose bolts, the 2 long ones  that run from back to front of housing, seen lots of these come loose and cause hard starting.
See how you get on.
https://www.bigmacktrucks.com/topic/70369-mack-vision/#findComment-507973
Thanks DMM, easy to get confused with different terminology.
 Mackpro, over 1400amps, those starters must've been glowing red hot.
Engine to frame earth/ ground on the ones down here in Aus will be on the passenger side👍
  • Haha 1
https://www.bigmacktrucks.com/topic/70369-mack-vision/#findComment-508078
