Yup, if you get through 12 hrs without having to build 120# you are lucky.
My .02 is the air wiper switch and shutters are the two main sources of leaks when truck is shut down.  You may have other possible leaks but if the truck is pretty sound, the two things I mentioned will cause the quickest leaks.
The wiper switch is a single O ring and the shutter is a rubber cup seal.
https://www.bigmacktrucks.com/topic/70376-air-prssure-loss/#findComment-508113
