Hello Paul,. I may have info. Are the rears 200 series or 112/113 Carriers? I can check my books tomorrow, and hope to help you..  what year-ish are they?  Jojo
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508556
I believe back then, 1980, they still stamped the info on the front just below the input housing, on the smooth curved part of the main housing..
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508595
Paul,  For some reason I am not able to send pictures to my Email from my phone.  I have a picture of a chart that may help you, but my normal way of sending pictures is not working..  Hopefully, when you clean the paint off the front of the carrier housing, you will see the series and ratio..   i expect it to be 112/113 series.. I'm trying,  Jojo
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508601
Thanks Joey
Went for a look see and returned with some info
Looks like 113, I have never had a issue with these at all so have never looked before
These were 5.73 ratio when new and for some reason I thought they had been changed to 5.29, Vlad pulled me up one day and said there was no such thing, I  don't know but said I would find out next time I'm under there
Looks like 5.32 to my eyes, reckon they would be the original carriers with new gears put in as 58's are pretty rare out here
Paul
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508637
5.32 is a legit ratio.  I have a chart that I want to send you but I dont have a phone number to text to, or an e-mail..   of course I respect one's privacy..  ... :) Jojo
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508639
Yes Vlad was right, just getting out and going for the day over
Have sent you my email address Joey
Thanks for helping
Yeah, I have no idea were I got 5.29 in my brain from
5.32 is plenty slow enough and would give you blokes a fit if I drove on the states at 55 MPH all day like I do out here
Paul
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508648
Wouldnt bother me....   I want to move the load, not win the race...  however, if you have to haul many loads in a day, the bossman will be on youre a$$..   I did a few years in construction pulling dump trailers and some 'wheeler work',,  I always was 1 or 2 loads / day shy of the seasoned guys,   But I never tried to get a speeding ticket as well..  anyway....    :) jojo
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508649
Photo of ratios sent to me from Joey
So after discussing this with Joey I reckon it would good to share this info with all as these questions are asked plenty of times on here
From the chart above (correct me if Im wrong Joey)
On the left hand vertical column of the main group of numbers is ratio of the top half of the diff center
I am calling the top half the bit that turns the drive to a right angle
So once I  establish that I can then go across the line horizontally and find my ratios that are available with that top section of gearing
So my truck had 5.73 to begin with, now has 5.32
So I find those two numbers and that tells me what ratios are available if I only change the lower section, from 4.64 - 6.48
If I  only change the top section and leave the lower gears as is I can have from 3.87 - 8.90, that is starting at my 5.32 as my base ratio
Is this correct Joey ?
Paul
Also let me know if it isnt okay to share this stuff Joey and I'll delete it
Seeyah
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508733
your doing good Paul,  to use this chart to the fullest, the carrier needs to be taken apart..  as far as the spur and bull gear, my bet is they will remain.  the top reduction (bevel gears) is where you will make your adjustment,  however,,  i have always built these with stock replacement sets, and I would use the mearsurements for shimming, and to make sure I had the right gears..  I also wish It wasnt 5 or 6 years ago when I built one.. you can also count the teeth on the gears and dived them into each othe to get the 2 gear ratios, (bevel gears + Spur and bull gear)...  I hope others will come in and add to or correct me if needed...  You Got this Mate...  Jojo
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508737
I just sent you an e-mail..  it is still sending, check it in a bit..   I'm sending pics from "Mack" books, instead of my brain..   :)   jojo
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508745
50K and up to 60 k-ish were 112/113, back then,,  92/93 were below 50K,  the 112/113/  had a stronger spur shaft housing and I think the bull gear is a bit wider...  Much like the 200 series, if memory serves me right..  I do know the 200 series was a stronger setup than the 92/93 series, as I described..  jojo
Edited by Joey Mack
more content needed
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508746
From a email from Joey yesterday
I noticed in the second picture down it says that 200 & 201 can be used in 50 and 58,000 pound axles
What ratios are there for these
And is 200 for 50,000 pound and 201 for 58,000 pound?
Paul
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508861
I gather thats the same for 112/113 and so on
Do you have the ratios for the 200 series carriers Joey ?
I have no idea were I'll find spare carriers for 58's in Australia, first I need to work out what ratio I'm looking for
Paul
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508949
as Far as I know, you can use the same ratio's...  The 200's are strong, but I have seen many 92/93's do a great job..  I dont see an issue...  and 92/93's are everywhere,  so you can hoard a few to do what you need to do..  I dont think I helped much Paul...  I really hope a smarter guy chimes in... :)   jojo
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508951
So do the other carriers fit in ? As in the 92/93 fit the 112/113's axle housings
Im thinking but have no idea the spider gears would have to be changed tp suit bigger axles
I know notjing about this stuff at all so any help is helpful
Paul
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508964
the mount bolt pattern is the same..   after around 2010-ish i think is when they added another bolt inside the carrier housing..  so your good...  as far as the axle housing,  how it is mounted into the truck is different, as you know..  spider gears in a Mack rear end are housed inside the bull gear, so no need to go that deep in that..  if you get the chance,, get a blown up mack rear from a friend and tear it apart..  as smart as you are you will say... "oh hell I get this'...   jojo
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508966
1 hour ago, mrsmackpaul said:
Crack,  what crack
Sorry Mate, I thought that this was a Crack....But upon cleaning My specs I see I was wrong..
Gotta remember seed this wild beast 320 unbridled horse power, takes a lot to harness that much energy
Yeah I know.. I had one in an F Model back in the Day..
  • Haha 1
Because those that matter...
don't mind...
And those that mind....
don't matter." -
https://www.bigmacktrucks.com/topic/70396-what-ratios/#findComment-508990
