E7 ecu came back from suspension place with codes 2-2 2-4 and 3-3 I think they line bored the front hangers without disconnecting the batterys
Now I've test all the wiring harness for a shorts to ground and to each other in which I found at the coolant temp sensor the was 4.5v on both wires so I unplug the fic module and the 4.5 voltage went away on the ground wire
So we swapped the fic module with a known good unit out of one of our other trucks and that seem to fix the problem however we left it plugged it and went away for work we came back to it the truck had the same faults and we think its fried a second module
The truck won't start unless the throttle is held flat and if you drive the truck it sputters around 1200rpm on deceleration like it loses RPM signal or something
Any help would be much appreciated also we're from Australia 🇦🇺
https://www.bigmacktrucks.com/topic/70456-ch-e7-engine-ecu-faults/
G'day Moose,
What year's your CH?
Pre Etech E7 would be Vmac 2 which doesn't list a 3-3 flash code, 2-2 would be coolant temp sensor and 2-4 would be intake air temp sensor
Vmac 2 manual https://macktrucks.vg-emedia.com/ProductDetail.aspx?ProductId=6112
Etech and ccrs are Vmac 3,which lists 2-2 as boost air pressure sensor, 2-4 as transmission oil temp sensor, and 3-3 as engine speed/ position sensor
Vmac 3 manual https://macktrucks.vg-emedia.com/ProductListing.aspx?keyword=8-211
1 hour ago, Adkat said:
G'day Moose,
With FIC module would make it vmac 1!
2 hours ago, Adkat said:
G'day Moose,
Yea mate it's a Vmac1 has the 2 separate modules and the year is a 93 build
Edited by Moose Mack
