I have a 2000 rd688 that is a dump truck. When the air pressure gets to about 100 the cab raises up a little in the rear. I’m thinking this is to only level the cab. Can airbags bring added to this truck for ride comfort? Had an old trucker to tell me I should add airbags to cab and it would ride a lot better and help my front suspension.
https://www.bigmacktrucks.com/topic/70504-does-my-truck-have-air-ride-cab/
your truck already has air ride cab.
as JoJo suggested, check the shocks and cab leveler valve and rods. they are probably shot after 22 years.
Let’s dummy this down please.
Joey is saying shocks. If I’m understanding you guys I already have shocks under cab which are probably wore out. Are those air shocks? How can I check them?
Mechohaulic is talking airbags and this would be totally different than what I have correct?
Ok . So the cab ride is out of adjustment. Could be due to worn or broken control rod..  at this point, start fresh..  new leveling valve, rod, air bag/s, and cab shocks..  you can un hook the Control rod, when air is above 100, and raise the cab by hand with the valve lever, place a block of wood under the cab edge. And make the repair..  the air bags unscrew from the cab , if they are stuck, you can un do the bottom, remove the air line and use an oil filter wrench to get thém out..
Edited by Joey Mack
Poor sperring
No. It is super easy..  what you see is what it is..  really is an easy repair. Raise the body, set the body braces in place, and right there behind the cylinder, is everything, right in the open..  all the work is done out side the cab, at the rear..
As Joey has said, super easy
Okay here is my observations of many air ride R models
I have never had to change shockers, I  have always found that the linkage between the ride height valve and the cab isnt strong enough and must slowly over time bend thru normal use
If I  disconnect the linkage and operate the valve until I have 1 1/2 - 2 inches between the rubber stop and the bottom of the cab it sits on the ride is improved to level of comfort a Mack owner can only dream of
The little air bag should be sitting reasonably stout but not fully extended
Lift the little arm up and down, fully extend the air bag, the fully collapse it
This will give you a good indication of were you want it to sit and the clearance available
So once you have established this bend the linkage to suit, however the trick is to have it just a tad higher than were you want so any slack in the valve linkages and the valve and the connecting rod are taken up
Now the lecture, dont waste your time undoing and trying to adjust the ends like most knob jockeys do at the start, remember this was the correct setting when it left the factory and has slowly bent
And there wont be enough thread to get the extra length needed
Then sit back and just glide along on a cushion of air, oh yeah baby it will be like a whole new truck
Anyway this is what I have found
Paul
Hey Paul, Do you have the part number for those air bags you posted..   I want to add something like that to my old '48 Int. KB-7..  It looks like I would get a Smooth Ride..  :) jojo
  • Haha 1
NOW THIS HAS TO STOP!! LOL  when I laugh this much I cough uncontrollably 😂😂. wife wanted to know what was so funny;; I showed her . positive response ;:: i just won't post it .sorry honey your 36 D's are nice , but ! LOL
I WILL NOT !! show my boss, I mean my wife the post...   :)   Jojo   Hell no !!!!
Edited by Joey Mack
Poor sperring
  • Haha 2
chicken....
it is obvious who wears the pants in your house!!!!  🤣
  • Haha 2
and also happily single now.
i never replaced the money spending blood sucking leech after the last one left.
  • Haha 1
