Will be swapping a good running ENDT 675 235hp from a truck with a bad body, into another chassis that's already equipped with a 235, but is worn out.  Both are 107 6 speed trucks.
The donor engine runs like a top, but I would like to re-seal or service anything that should get done when the engine is out of the truck.   Rear main, oil pan etc. Im new to swapping these engines, can anyone give me a quick "list" of things I should look at while the engine is out and easily serviced?  It will be getting a new clutch while it's out, jacobs 675 jake heads (overhead adj obviously) and fresh injectors, hoses etc.
https://www.bigmacktrucks.com/topic/70511-235-swap/
what you do to it would depend largely on ;; how did it run, sound before removal from chassis. new clutch is being installed. mileage on it , blow-by are factors. other then clutch,rear seal  anything else can be done in chassis. runs like a top , shouldn't need internals. a coat of paint would be only item done easier out of frame . LOL
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-510726
Are there any leak prone seals or anything that would be easier addressed while the engine is out?   It's going into a Western Mack, so narrower frame rails make a few areas like around the compressor and power steering pump, difficult to access.
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-510762
IMO,  without ever doing a swap like yours....   Shouldnt you just take everything off, clean/buff it and reseal it?  even if you have to cut your own gaskets..  I am probably stating some obvious stuff,  but it is what I do...  I have had a few older units apart recently, and I do just that...  remove all covers, used and un-used, and make gaskets..  A great RTV can be your friend..  Mack Gray for example..  jojo
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-510763
major factor  would be 1-are you doing this for yourself or as  in  JOJO's builds most /all are for customers. with the high quality workmanship from JOJO a customers engine receives a total overhaul.  if this unit is for yourself, common sense would play important roll. not knowing mileage/hrs on donor then time and $$$$ would be an  important consider. understand the original question about easy access to possible future problems while out of frame . air tanks from donor show oil etc. time frame for getting unit back and running would make a difference to how far you rip and tear.
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-510768
Mech...  you are too kind...........  Good points on easy access..  My thoughts were for anything that may leak..   Certainly, he need's to know the Health of the engine.. He did say it is a good runner...   as we all know....  these projects, become bigger as we look deep or behind stuff..  anyway....  If its a good runner...  re-seal the ''bolt-on's '' and run it..    Of course if he has a crystal ball,,  when He's done with it, he can rent it out to me,   and then I will sub-let it to the next guy...   and so-on...  :)   jojo
  • Haha 1
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-510770
Yes, I think re-sealing as much as possible is the ticket.  Front and rear mains, timing cover manifold gaskets?  oil pain.  Not the head gaskets.  does the oil cooler have any seals?   It runs and starts great, no blow by, no leaks, no oil in air tanks that I tell.  about 8000hrs on it.   320,000miles or so.  It hasn't been worked as hard as some.   I could just throw it in as is, but i'd like to do a little better then that.   Freshen it up a bit, and bump up the reliability factor.
This is a project for ME to use, not doing this on a customers truck.  It's being made into a single axle rollback truck and will work daily.  With me driving it, no cowboys.
Edited by Full Floater
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-510774
Once again... you got this..   I assume you have a really good skill set, so these P.M. item's will be in your zone.. leave the heads alone if you are confident in their performance..  and the engines performance..  Just keep up with us, post some pics and enjoy the "Like's"   ....  jojo
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-510776
  • 3 months later...
Does anyone have any insight as to what crank main seals I should order?  In particular, the rear?  And is there a special service tool needed to install the seal on these?
I have done many a crank seal, but never on a Mack 675....so just want to make sure this guy goes in right.
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520556
Here is some info on the seal installer.. I have several tools from this company..  Monaco tools.com,,, tool #50112-A....  $595.00.
Edited by Joey Mack
Pore cell fone sperring
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520606
3 minutes ago, Joey Mack said:
Here is some info on the seal installer.. I had several tools from this company..  Monaco tools.com,,, tool #50112-A....  $595.00.
times have changed . $600.oo for a tool !! i could justify it being in your work JoJo, a customers vehicle has to be right and the tool will be used more then once. a single use ;;look to borrow/rent one. or piece of pipe right diameter drill three hole on welded cap end so it bolts to crank for square pull on install.  glad I'm out of the tool buying need.
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520608
Yes sir Mech. it sure is a lot of money for the tool, if you may not use it again..  The advantage of the tool, is that it can install a wear ring as well as the seal, and set it to the proper depth.. if a wear ring is not needed, I would say you could make a tool to set the seal in nice and straight..  Jojo
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520609
2 hours ago, mechohaulic said:
another tech advancement by sounds. rear main seal use to be a piece of babit . now there was a challenge; rolling that into the rear seal housing. trial and error in/out till it was perfect.
Yes, the manual that I have, shows and describes this process.  I hadn't seen it before and it scared me haha.   It also shows a lip style seal and states there are a few different options.   I try to acquire the parts I need prior to tearing into something but maybe I should tear into this and find out exactly what is in there.   OR just leave it alone :)
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520616
2 hours ago, Joey Mack said:
Forgive me, but is a 675 still an E-6?  Like an ENDT 673?  If so, I bought a rear main seal tool for both E-7 and E-6, from Tillmantool.com.
Sure seems as if a lot of parts interchange between the E6....not sure exactly what's what with that.
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520618
And the reason I left mine alone.  Lol.  Can of worms I didn't want to open.
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520621
Did it show the procedure to set the run-out on the flywheel housing?  I wish I was smarter about E-6's..  I think the seal housing is seperate from the flywheel housing.  Which may make it easier to install the new style rear mains..  then you can install the seal housing.....  I was wondering if you should check run-out on the flywheel housing first while the crank hub is out in the open, then do the rear main seal..  I wonder what the Dog Pound thinks about that??  jojo
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520623
seems to me ; the crank hub is the same with or without the rear seal housing installed= based on the dinosaur days (my time slot ) . dial indicator mounts to the crank hub which is extended out from seal housing. the 1/8th + - extension is where the flywheel rest.
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520646
On the old engines that used the lead wire on the crank the crank had a slinger for throwing the oil out and that is what kelp the oil from leaking but the lead wire seal was only a dust seal.We pull the cover off ever time we did a clutch and rolled a now wire in the cover.A later seal cover could be used there but the seal was a very narrow seal because the crank was short there as a sealing area.
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520678
Is the later seal a preferable replacement?
https://www.bigmacktrucks.com/topic/70511-235-swap/#findComment-520795
