1 hour ago, theakerstwo said:
Are you talking about the flywheel housing or the trans bell housing?The flywheel housing will be same but the trans housing will not work from a mack trans to a eaton
Yup you need a mack/ eaton  trans bellhousing mounts on the trans for E9 or any Mack engine any 18 speed fuller  pulled from a Mack  will fit behind an E9 you may have to alter the clutch cable mount and arm! ! Western star and Mack had similar ideas on engine mounts however Mack Mounts are better ! Way easier to remove than Star in most cases due to the clutch arm on the star!!
https://www.bigmacktrucks.com/topic/70520-e9-bell-housing/#findComment-510958
