i used to run there every monday and wednesday  i dont go there anymore ill figure something out if you really need it,,,,,this one is in pretty good shape for its age,,,,very flexible and no cracks...but if i were you i would try to find a new one first i actually have the complete door...bob
Left door I’m going to use ,,,,,right door is available I don’t know if you need the left side I am going to change out the one I have on the DM Right now,,,,; UPS door is flawless  left side I have on there now I fixed a slight dent in it long time ago there’s no rot on it but the UPS door was better bottom line is here left and right doors will both be available Soon if you  need either one of them… bob
I don’t have any rims and no I have not found the dashboard parts if you want to drivers door it’s yours 150 that’s what I paid for 27 years ago it’s in pretty good shape but I need the window regulator section out of it… bob
  On 11/6/2022 at 1:13 AM, Quickfarms said:
Today was fun
we found the second injector on both sides were stuck. The drivers side one was easy to free up, the passenger side one required the removal of the rocker bolts to gain access.
Then we discovered the truck was actually positive ground.
then the starter solenoid was not behaving
We did get the truck to run but there is no fuel coming back from the lift pump.
now we need to change the filters and work on priming this thing
Expand
I haven't seen the underside of that style valve cover in years. still have the adjusting tools for lifters and injectors. the fun days for sure. to get all injectors to flip the same ; 4 the same not bad to match both  sides :challenging
  • 5 weeks later...
  On 12/8/2022 at 12:11 PM, mowerman said:
Not sure what happened to you but here lately there  has been two guys parting out R models steel  dashboards bob
Expand
Who are they?
I have been checking this regularly but have been really busy with work so I guess I missed the posts, can you point me in there direction
  • 4 weeks later...
  • 4 months later...
This project has been on hold for a few months
we had the wettest winter in Southern California I can remember in decades
So today we spent the day working on the truck. After new fuel filters and repriming we pulled the air cleaner and we were ready to give it some starting fluid but as soon as it turned over it started and ran at a smooth idle with 35 lbs oil pressure
so now I need to replace the air shutoff solenoid due to a large air leak. The fuel return hose is also leaking. The one leak that we can’t find the source is there is oil in the rear valley near where the slober tube is bolted on but we can’t see an obvious source
I have been busy with other projects and working, traveling, and going to shows
this Mack also recieved three new air hoses, and two newer air cans
yesterday I turned it around in the yard so it could park in the line
it will still take a lot of work before it is on the road but now it can move around the yard under its own power, which was the immediate goal
