I have a CL with and e9 in-line pump that has an air throttle it hasn’t ever gave me any issues other that being a little touchy on big bounces but It’s gotten really touchy the last couple days when I’m loaded or empty and go over a bounce the slightest movement from my foot gives it throttle and jerks the drive train I have no air  leaks and both return springs are still on  could the problem  be in the fuel pump possibly
https://www.bigmacktrucks.com/topic/70543-e9-air-throttle/
40 minutes ago, fjh said:
May be the the throttle lever on the fuel pump it is spring loaded as  well as all the other springs ! check the pinch bolt for tightness and the little spring on the lever shaft for wear!
Checked that too everything visible is in working order
https://www.bigmacktrucks.com/topic/70543-e9-air-throttle/#findComment-511545
