There is a metal “L” bracket that is on the steering column bracket. This “L” bracket serves as a upper stop to keep the clutch pedal from coming up to high. There also a rubber bumper on this “L” bracket. The rubber bumper usually falls off and the “L” slowly get bent up allowing the clutch pedal to go higher. This is Partially due to incorrect clutch adjustment and /or the clutch cable length adjustment or stretch. I’ve seen people bend the “L “ bracket up to get clutch free travel when their clutch wouldn’t adjust anymore. If you have the big “grated” clutch pedal,, it was a option. You can get the standard pedal still I believe. It was easy to change,
https://www.bigmacktrucks.com/topic/70646-cl-clutch-pedal/#findComment-514239
28 minutes ago, Mackpro said:
The upper black rubber bumper part number is 12AX141
Did I ever mention that these guys are amazing?!
https://www.bigmacktrucks.com/topic/70646-cl-clutch-pedal/#findComment-514250
