Pulling injectors on a 673
Go to solution Solved by theakerstwo,
Here’s the link, if that will help you and yes, there are used to be a lot of them around and around here  even up till recently the last ones I knew of was US mail. They were using them up till just a few years ago…. Bob
4 minutes ago, mowerman said:
Punch in H model with air start on google it’s a great little video
have to say the H model may have been a quirky looking with the little bubble nose ; at same time a different  all around truck. higher cab had visibility  and shorter cab
1 minute ago, mechohaulic said:
thanks for video: i will log off here and check it. wouldn't go through for me on here.
No, I didn’t think you could open it. I was just showing you which one it was.
1 minute ago, mowerman said:
Ha ha the closest I’ve ever got to one one except that shows I sat in one in a wrecking yard somewhere around 1970 as a young kid.. Bob
Don't look now !!! we are going off topic AGAIN.  I put short version of me and a H67 on frozen clutch topic. yrs back two old timers came to waterbury mack from Maine to look at a H67 single axle for sale. dead winter cold ; tow truck hooked to H model. I'm in the H. boss and two buyer watch as tow truck pulls me to start. tow truck stops ;I didn't . the H had a twin stick duplex. everything so cold  i thought both sticks in gear:: aux wasn't .SMASH  into plate on wrecker with the bubble nose. my boss (big guy) races over to me : "get out of that truck you fu--in assole. two buys never said a word; got in their vehicle and left. so summary:: my H model story didn't have a happy ending LOL
Well you fill it up with air and try again
I really cant imagine a air start is much good in a cold part of the world, the air valves freeze in Australia at -5 C which according to google is 23 F and it gets a lot colder than that in parts of North America I believe
Apart from the novelty air start is a bit of a pain in the neck, battery technology has improved so much that air start has been made a non event even in tough going areas of Australia
Paul
Well I guess I was thinking more along the lines of if air wasn’t available in the location you may be at in that time. So essentially you are screwed. Still a baddass system.
Nah, there's a hose with a fitting to drain the tyres to recharge the tank, three tyres apparently gives you enough to get here going
Once your started you refill the tyres from the trucks compressor
As I said a pain in the neck
Paul
I can get 8-9 seconds of cranking on a full tank.  Since mine lives indoors all winter I haven't had the need to see if it will start in the cold anymore.  This video, I only had like 80# in the tank to start with and it starts faster then you can release the button.
I may, just for giggles, leave it out in the dead cold one night this winter just to see how it starts, unaided.
one of the reasons air start vehicles had larger volume  air tanks. as with all mechanical devices ; each one has it's down fall. back then engines could handle the forbidden  ether can. many of winter road calls for no start / no air.
Is be curious to see what the actual gallon size my tank is?  It is an alum tank from an R model.  One of the larger ones I've seen, length wise.  It's hanging under the bunk in my signature picture.
I've see ones that are near 1/2 as long as mine.
Apparently there was a 1 start, 2 start and a 3 start tank
The single start tanks are really short
Maybe only 6 to 8 inches of flat if measured length ways
2 start tanks are about 12 inches of flat
3 start are longer at a guess 18 - 24 inches
I reckon on some old B models I have seen even longer again
Paul
