  • 0
Electronic malfunction light
Question
3 answers to this question
  • 0
with cruise off and engine at idle, push cruise button up one time to set, than count the EML flashes. that code will tell you what the issue is.
  • 0
no programming to be done on a '91..  check the adjustment of the speed sensor in the tranny output housing...  It goes all the way in (gently) then 1 full turn out..  you may want to remove it and check it for damage. jojo
Answer this question...
