Has anyone rebuilt the water pump from a 673?. While I doubt that there is. specific "kit" available for this, it should be just a seal and a bearing or two. While it is possible that one or both of these items are no longer available, bearings an d seals are so common that I would be surprised if the ones in this water pump are "special". For all I know this pump could be fine but thought for what it would take, t would be prudent to just refresh it now while it is off. Thoughts?
https://www.bigmacktrucks.com/topic/70738-water-pump-thoughts/
I've seen guys on here talk about houses that DO rebuild these pumps.  So, I would assume you are correct, and one would just need the know-how to do it.  I'm sure somebody here will have some detailed advice.
How's the wing?
  • Haha 1
https://www.bigmacktrucks.com/topic/70738-water-pump-thoughts/#findComment-515721
5 hours ago, Licensed to kill said:
Wing is doing well. Can move my fingers now. Should have the splint off in a week then 6 weeks of rehab for strength and mobility. Bored as hell though.
I'm glad you are improving.
https://www.bigmacktrucks.com/topic/70738-water-pump-thoughts/#findComment-515788
I’m sure I have the invoice, I’ll dig it out.I do know I had a new Water Pump, from some old NOS stuff I bought but the shaft was a different length . The one I got from H&H P was correct, I’ll find the part number
https://www.bigmacktrucks.com/topic/70738-water-pump-thoughts/#findComment-515826
14 hours ago, Big R said:
I have a water pump I removed a couple years ago from a ends 673. You are welcome to it if you would like to see what you can do without removing yours
I appreciate the offer but I have two water pumps. I do not know the condition of them other than they spin free and smooth, just thought I would replace bearings and seal while it is on the bench.
https://www.bigmacktrucks.com/topic/70738-water-pump-thoughts/#findComment-515988
