2000 ch613 with a I believe a 2090 transmission.  The one that has the odd shift pattern ( doesn’t use the high gear in low range). What oil should be in it.  Servicing the whole truck a was gonna change it.  We always had used 80/90 in others but read now that that may not be right.
https://www.bigmacktrucks.com/topic/70926-2090-transmission-oil/
If you dont have one of these books for your year model, I suggest you try to get one. They are a wealth of information...  Of course Mackpro is also a wealth of knowledge.  but.... just in case he's not around, this book will help...  :)
