2000 ch613 with a I believe a 2090 transmission.  The one that has the odd shift pattern ( doesn’t use the high gear in low range). What oil should be in it.  Servicing the whole truck a was gonna change it.  We always had used 80/90 in others but read now that that may not be right.
https://www.bigmacktrucks.com/topic/70927-2090-transmission-oil/
Mack tranny's since the mid. 90's took 75W90 synth. From the factory..  Do you have a Maint. And Lube book?  There should be other grade listings for the region and usage..
