I have an e9 noticed I’m starting to get a little oil residue on the cold side can anyone tell me what turbo this is I don’t think it’s stock considering it pushes 36psi on a warm day and 40psi on a cold day i know stock should only be 28psi these are the only numbers I can find there’s no tag where they normally are
https://www.bigmacktrucks.com/topic/70934-e9-turbo/
As a last result you may have to take it out and measure inlet diameter, turbine diameter, and exhaust housing diameter to find a similar turbo. It could have been ordered from a catalog that's long gone by now.
Do you want to go back to a stock turbo or do you want to find whatever turbo is on there?
https://www.bigmacktrucks.com/topic/70934-e9-turbo/#findComment-519154
I don’t know where you live how ever if you got a local fuel shop you might want to check with them! Also mak sure your air filter is clean this has caused issues in the past specially with a high output turbo and fueled up engines! In the land of oz the v8 was or could produce 650-700 hp we installed an ozy turbo on several trucks here and as your observation 35-40 psi boost was not uncommon! Just tweaked the fuel to the need! Note the drain tube was a little different so beware!
https://www.bigmacktrucks.com/topic/70934-e9-turbo/#findComment-519158
Hmm I would say that psi wouldn't be uncommon for a big V8. I had a 515hp Detroit 60's series in my 2005 Freightliner Coronado that would push almost 50psi at times under a pull. Sounded like a 747 gittin ready for take off when you fired her up lol.
https://www.bigmacktrucks.com/topic/70934-e9-turbo/#findComment-519165
I wanna get the same one
https://www.bigmacktrucks.com/topic/70934-e9-turbo/#findComment-519167
Yes it’s in a dump truck I change the air filter once a month as preventative maintenance and yes the drain tube looks like a accordion
https://www.bigmacktrucks.com/topic/70934-e9-turbo/#findComment-519168
