  • 0
2001 RD690S pre-purchase questions
Question
Hey guys,
Still looking for a truck and ran across a 2001 RD690S.
Question 1
The VIN is 1M1P270Y71M055417.  Looking through all the info I have found it looks like the Y in digit 8 indicates "Class 8 GVWR Truck tractor with air brake system".  Does that mean it started out as a road tractor and was converted to a dump truck?  If it was a C in the 8th digit it says "Class 8 GVWR Truck with air brake".
If it was a conversion are there any red flags to look for?
Question 2
Really confused about RD688 vs RD690.  From what I have read it was used to indicate Econodyne vs Maxidyne and the typical transmissions used (with Maxi's using a Mack trans).  Was this still true in 2001.  This is a RD690S with a 400hp Mack motor and a Fuller 8LL trans.  I thought 690's had Mack transmissions in them.
Thanks for you input,
Dave
https://www.bigmacktrucks.com/topic/70968-2001-rd690s-pre-purchase-questions/
1 answer to this question
  • 0
That VIN comes back to a RD688S, built 4/11/2000.  Engine is a standard ETECH 400. Trans is a Mack T-2090. steer axle is a FAW12 ( 12,000 pound I believe) . Rear carriers are Mack 200 series with 4.73 gears. . Has 10 leaf camelback springs .
Answer this question...
