The engine brakes on that engine were weak from the start.  There were a few updates to try to improve them.. maybe get the valve adjustment checked, and set the engine brake gap to .021" ,.
https://www.bigmacktrucks.com/topic/70969-vin-check/#findComment-519949
  On 1/4/2023 at 10:33 AM, Ray57 said:
U mean no engine brake at all because i put the engine brake and works but not that strong thanks for the great info
Expand
The software page said no engine brake but I went back on the parts side and it does have the Jacob’s engine brake. As Joey said , the jakes on these engines are mostly noise makers . But there are a ton of updates that can be done to help them perform better, everything from high volume oil pumps to external oil line kits to plunger lots. Some items might no longer be available though.
https://www.bigmacktrucks.com/topic/70969-vin-check/#findComment-519951
