hi all,
Long time lurker of posts, thank you all for the vast knowledge on here, I've used info many times, it is my First time posting;
So I have a 2006 CXN613 vision , with AC460 CEGR engine.
I have been having intermittent low power/ low boost problems with the truck, sometimes truck pulls great and makes 30+ psi boost, others can't get the truck to hold 5 psi. Seems to happen more frequently after about 1hr of use. I've had the truck to several garages, all to no avail.
Some background on what has been done:
I have checked for loose wires at eecu connectors (as this had been a problem causing truck to shut down while driving in the past)
I have replaced and calibrated fuel pedal, all good.
I have checked VTG operation visually and while driving with a GoPro, all seems good.
I have disconnected and pressure tested charge air cooler and piping, no leaks.
 Fresh fuel filters, air filter, no fuel restrictions
No current active codes (getting an occasional 6-4 flash code, but not corresponding with low power occurrence.
I have replaced boost pressure relief valve, thought this was my issue as I tested it and it was weak, opening at 3-4psi; when I replaced valve, after first startup the truck sort of coughed and ran rough for a second putting out blue smoke, test drove the truck bobtail, it pulled like a race car (maxing out boost gauge I installed) , I was excited thought I had issue resolved. Truck went to work the next day, ran great for about an hour loaded then lost power. No codes present.
Anyone have any suggestions on where I should look next.
Thanks
I have not, will try that tomorrow. thats the small one on drivers side of engine by side of frame rail?
I did disconnect stainless air line going to actuator and there seemed to be lots of air, didn't pressure check it or anything though. Put a small bit of shop air to actuator and it moved rod up and down easily.
Thats the filter..  A lot of folks dont change it anually, as it should be..  The module that it filters the air for, is expensive, I suggest you put that filter on your P.M. schedule..  I should know the part number, but I dont... sorry..  If you can read the filter number, call NAPA and get a cross reference..  Lets keep it simple from the start..   No need to load a parts cannon with hi dollar parts, only to find it was a filter or broken wire,,,  Jojo
You did good replacing that bypass valve they were made to start reliving around 20 psi it sounds to me that ! That new valve stuck for the first bit! I did alot of messing about with these when the engine first appeared on the seen ! I corked that bypass off completely on one truck ! The Vgt will generate WAY MORE air than that engine needs regardless of fuel ! It will pound the boost gauge to the MAX on a regular basis! The valve is meant to protect the turbo from Over Spooling  and God Knows  these turbos had a bunch of issues in the beginning! That said The EGR valve stuck open is another thing that could have been happening here ! Don't know give the stuff Joey has presented A try ! Keep us posted!
thanks Fjh,
when diagnosing I actually put a 1" plug in there where the boost relief valve goes and the truck ran great, pulled great and pounded boost gauge every time, this is why I thought I had the problem corrected..... no doubt I did have a worn out boost pressure relief valve but thats obviously not my only problem.
In thinking of it; it was when I installed the plug on first start up the truck coughed when revved at idle (almost sounded like Jake on) and put out blue smoke out the stack and back through the tube that connects to bpr valve, could this be an indication of stuck egr or something else ? truck has not smoked noticeably when experiencing low power issues, nor coughed, just gradually dies out.
I have the small air filter on order to arrive tomorrow that joey has mentioned above, we will see what that does too
hey guys,
update: I have changed the small air filter for actuator like joey mentioned, I have also replaced boost pressure sensor. still no change. checked tank vents also, all good.
I am getting an active 6-4 code all the time,
truck works fine sometimes and pulls great, seems like after it works for about an hour it loses power, making little boost.
Any suggestions ? would this 6-4 code be any guidance
  On 1/17/2023 at 2:24 AM, griffvision said:
hey guys,
Expand
Bro ! Check the ECU plugs for coolant push or oil push! un plug them and look for signs of this!
  • 2 years later...
