19 minutes ago, 1wonton said:
Have the 673 C engine (five speed transmission) in my B 61; Is this engine similar to the Maxidyne and/or will it handle low rpms like the Maxi?
Is it a straight 5 spd, i believe that engine should be hooked to a triplex, quad series transmission.    terry:MackLogo:
https://www.bigmacktrucks.com/topic/71017-673-c-engine/#findComment-520794
The C engine is rated at 250hp, but it is a thermodyne and will need more then 5 spds.  Under a load it will really struggle to recover speed at 1100 rpm when you shift.  It needs to be around 1500-1600 rpm.  On a hill it will really hurt it.
I was really hunting for one of these motors to replace my old P motor for many years.  The 237 showed up and I went that way instead.  It has its own issues with being ahead of a Triplex(single countershaft transmission).  You can't lug it down to 1100 as it will try to spit the gears out.  So I drive it more like a thermodyne.
https://www.bigmacktrucks.com/topic/71017-673-c-engine/#findComment-520810
It is not the original 673.  It is the EDNT 673C, 250 hp Turbo, mated to a five speed trans.  Seems to have lots of torque at 1100-1200, never really lugged it down to stall.  Just wondering how it compared with the Maxi from anyone's experience.
https://www.bigmacktrucks.com/topic/71017-673-c-engine/#findComment-520838
