- 0
2005 CV713 Maxitorque T310M/MLR Synchro Help
Question
Detailed0707
Hi all, have an 05 cv713 dump truck with a maxitorque T310m/mlr trans. I am getting a loud grind in neutral when coming from lo to hi range gears. Preselect or not preselecting, grinds nearly every time with no avail. Specifically 4th lo to 5th hi. Through lots of research I see the common culprit being the synchro issue. My question is trying to ensure I have the right part number fix before ordering. I have also seen to order through PAI for a cheaper alternative to Mack OEM. Is PN 806806 the correct kit I need to fix my lo to hi grind? Just double checking before ordering. As a side note, any recommendations for best site to order these from as there are several selling PAI with different pricing. Thanks in advance for the help!
https://www.bigmacktrucks.com/topic/72402-2005-cv713-maxitorque-t310mmlr-synchro-help/Share on other sites
4 answers to this question
