1 hour ago, james j neiweem said:
Is this a Diamond-T design and build in house
Diamond T.... yes.   Diamond Reo used it too.  Funny when White acquired it all they never used this design, and instead made that 5000 series .   I think these were also called "china closets"
  • Haha 1
https://www.bigmacktrucks.com/topic/72420-59-diamond-t/#findComment-524029
Interior is pretty well shot.
There's one on utube that has the same blue/white paint scheme.
The guy said the starter stays engaged and melted the battery terminal before he could get it off.
But its straight not rotted.
I'm flush on projects or I'd prolly pay the 2500 he's asking for it.
https://www.bigmacktrucks.com/topic/72420-59-diamond-t/#findComment-524222
Hippy
You Guessed right!!! That was the dipstick access and also it had a fitting on the air inlet pipe so you could squirt ether thru the door as the compression release cable handle was right behind the  shifting lever.. This model truck also had the counter balanced spring loaded cab tilt which was designed by the Murty Bros of Portland OR
Edited by Brocky
Brocky
https://www.bigmacktrucks.com/topic/72420-59-diamond-t/#findComment-524679
waterbury Mack was also a Diamond t dealer  for short time in the day. possibly it was standard  equipt on T's. put some time on the internet looking up  local companies of days gone by recently. now those pictures kicked in memories.
https://www.bigmacktrucks.com/topic/72420-59-diamond-t/#findComment-524754
On 2/5/2023 at 9:41 AM, Brocky said:
That is the Diamond T 931 which is a squared of version of the 921 which was the "China Closet".
Yest that is a sleeper on the back of the cab.. Also a carry over from the 921. This is my 1959 model 921.
That 921 has alot more character than the blue truck.
John
https://www.bigmacktrucks.com/topic/72420-59-diamond-t/#findComment-524939
The Royale was from when that oil guy briefly owned the company (after White)  Would have been around 1974 to 1975 .  Same time as The Raider was produced.
Just a fun little factoid .....  during the time of the Diamond T 921 and 931 they were under the leadership of Zenon Hansen.  Same guy that was in charge of our beloved Macks during the Maxidyne / R Model era .  Some believe he saved Mack at that point. (maybe he did)  Wish he had a grandkid to have saved it from Volvo.
https://www.bigmacktrucks.com/topic/72420-59-diamond-t/#findComment-525056
I heard Mack almost went bankrupt right around 1965 mismanaged and the R model was the only reason they stayed afloat I heard from 68 to 70 they sold more Mack’s than everything else combined. I don’t know how true that is but when I was a young teenager, all the turnpikes were packed with them U R and F models… Bob
https://www.bigmacktrucks.com/topic/72420-59-diamond-t/#findComment-525121
