1 minute ago, DaveB6875 said:
Hello, we have a TRT7220 trans in our B-75, We have a leak gear oil at the clutch brake. My question is can you replace the seal there without pulling the trans? Thank You
Hi is the clutch brake mounted on the counter shaft? do you have the seal?
Hello, yes, mounted on the countershaft, looks like you could do it, checking to see if anybody has done this before. Do not have a seal yet I have checked with Mack Museum about some info on the trans. Retired in July last year from 47 years a mechanic. Started out working on big trucks then at a township working on a variety of equipment, mowers, cars, trucks, tractors. When I started most of the Macks were 5 speeds or road rangers.
To be honest I only ever worked on one of these ! So I cant tell you  Much How ever I see know reason you couldnt reseal it in frame getting the seal in and out may be tricky thou! You'll likely have to fab up some special toolage!
the memory banks may be playing havoc with me right now but ;;1- I thought the front transmission cover on the older units had a 1/4 dia pin which went through the front input shaft and spun in cover which had a reverse spiral to keep oil from leaking. newer units I'm sure have a seal now. 2- to replace a seal,, trans would have to be removed in order for seal to go over input shaft. 3- a clutch brake disc CAN be replaced without trans removal. a pain in ass job but can be done using updated two piece disc.
