I have a 2000 CX613 with a 98 E7 460. I was told when I bought it that it had been ReMacked at 1.1, no paper work available. It is coming up on 1.6M. Since I’ve owned it (11/20) the #4 unit pump has had a slight fuel leak. It has been removed/replaced 3 times. We recently replaced the heads and rebuilt the jakes because of an oil leak where the heads meet. After about 2k miles I noticed my fuel mileage had dropped and I was making oil. It is definitely fuel not water getting in the oil.
My mechanic thinks he remembers that the head bolts around #4 cylinder had thread dope on them when he pulled them out. We did not use anything on them when we put them back in.
I know when we did the exhaust manifold we used thread dope on those bolts as they thread into the oil galley. It is also listed in a service bulletin. Is there any service bulletin that I missed with regards to the head bolts or do I have a much bigger problem.
https://www.bigmacktrucks.com/topic/72496-%E2%80%9Cmaking-oil%E2%80%9D/
That year model ETECH has excessive fuel from the injectors return back to the tank through passage ways inside the cylinder heads. A leaking top O-ring on the injectors can allow fuel into the oil. Seems likely due to it didn’t start till after the heads replaced. Put some fuel dye in the fuel filters and run the engine for one minute then remove valve covers and use a black  light to look for fuel around injector hold downs.
I re- built an E-Tech last summer that was making oil..  I took the fuel lift, pump off and put a plug in the output port, and shop air set to 80 PSI in the input port.  The fuel in the pump blew out passed the spindle where the gear is..  Bad Pump..  I also found on another one I re- built right after that, and it had a leaking fuel gallery plug, behind the timing cover..  My 2 issues aren't very common in my experience, but it happens.  For a bunch of years now, I will remove both the front gallery plugs, and reseal them as part of the rebuild.  Good luck..  Jojo
Edited by Joey Mack
Pore cell fone sperring
If you remove the valve covers and pull the injector hold downs you will see fuel on top of the injector ! this will cost nothing to do just a little time! that way you can confirm what Mack Pro is saying! just remember to torque them back in if you find nothing!
