  • 0
Any E6 Oil Pans Available? (51qt)
Question
Looking for replacement and none on the internet, believe me I tried. Any sites saying in stock are out of stock for the the aftermarket version PAI 240GB5212D.
Could be old laying in a field for all I care. Am about to just try and have a pro drill both sides of small small crack and then fab/weld it up maybe fill in some additional steel for added strength
https://www.bigmacktrucks.com/topic/72497-any-e6-oil-pans-available-51qt/
  • 0
On 2/10/2023 at 5:30 PM, fjh said:
I have suggestion! Convert to a 32 litre pan and just replace the oil pickup!
Adding to my response/quote, I basically found the answers with photo attached. Looks like a pretty short pickup, I gather it doesn’t sit at bottom of deep sump and like another member commented, the pickup works in both pans apparently. Wanted to know what was dealing with before I dropped pan and then needed something and had to do it twice
  • 0
Any chance of swiping the oil pickup off the truck you're getting the pan from? I doubt the pickups are different depending on pan.  Only differences I could foresee would be based on sump positioning. The pan and oil pump assembly can be flipped end for end depending on front axle to engine positioning, but I don't recall if there was a "center sump" oil pan.
Answer this question...
