Good afternoon everyone,
I’ve got a 2006 Mack cv713 smoking white with a loss of power and rough running truck throws a code for injector three so we swapped the eup for cylinder three and found no change codes the truck currently has I will attach to this and post below.
I always check the wires to the EUP's before I dive into the customers wallet..  They crack and chaffe, then short to ground on the engine block. Also check the EECU plugs for fluids and/or green stuff, inside the terminals.. I am not familiar with that computer diag system..  Do you know how to check active codes using the cruise control buttons?  jojo
Edited by Joey Mack
more content needed
