Truck developed an oil leak on top of transmission.   Pulled the cab floor up and found one bolt out of the shifter and the other three finger loose.   Can I lift that enough to put some sealant under it with out bad things happening.    My knowledge of a transmission shifter stopped when the old farmall would get caught between 2 gears!!!!
thanks guys!
https://www.bigmacktrucks.com/topic/72531-2090-shifting-tower/
thanks guys!
Sure can taking it out is no mystery  either just getter done!
https://www.bigmacktrucks.com/topic/72531-2090-shifting-tower/#findComment-525902
