possible for a little more history on this unit ?? hasn't run in yrs/ have been having fuel problems /  etc .. see it listed in fire apparatus. this is a fire unit  .runs rough and getting it ready for parade season ???  if the filters fuel is black smells like varnish   I would  think the fuel tank(s) need a flushing/ cleaning also.
If you got black fuel in filter housing, you may be having algae problems in fuel system which is going to ruin your play time. Can you drain some fuel from bottom of tank to see if it is black also. If it is, you need to do a system flush. Once that crap gets started, you got a mess
I wouldn't think twice about draining system completely and start all new fuel. cost of the new fuel has to be way lower then tow charge when it quits running on highway. which you would be buying all new fuel after anyhow.  have to;; use a 5 gallon can strapped to fender with line to eng to run unit. crud in filter housing indicates the tank condition sometimes ..
