We are sending our old Fontaine 5th wheel out for sandblasting and then we’ll give it a fresh coat of paint.
I know the Fontaine tag will be destroyed so it needs to be removed. I guess I’ll drill out the rivets but what’s the best way to reattach it when it’s done?
https://www.bigmacktrucks.com/topic/72711-5th-wheel/
2 minutes ago, mechohaulic said:
hope you have a steady hand to repaint the black letters and border on the fontaine tag.  not too shiny on the alum. it's an  ident tag not hood emblem
I forgot that most Ident tags were painted back then.
https://www.bigmacktrucks.com/topic/72711-5th-wheel/#findComment-529097
Why not just get some steel dome head rivets like are there now and reattach the proper way? You don't really need a riveting tool to install them since you have access to both sides of the hole. If you are careful and have some finesse you can install them with a hammer. Or just catch the backside of the rivet with a little low temperature MIG weld to keep it from pulling out. Either way I would just replace with new steel rivets once the 5th wheel is reconditioned. The rivets themselves are dirt cheap. Depending on the hole size the rivets are like $10 for 250 of them.
Edited by 67RModel
https://www.bigmacktrucks.com/topic/72711-5th-wheel/#findComment-529113
there are many ways to restore the 5th wheel. depends on the extent of restoration and $$$$ willing to spend. wheels off and parts available ;; do a rebuild. far as the tag carefully remove  it so blaster can get behind the tag. otherwise rust/scale behind it. permanent install can be accomplished by ALL the methods suggested.
https://www.bigmacktrucks.com/topic/72711-5th-wheel/#findComment-529136
