Mack GU813 S/N: 1M2AX16C9JM039991. When you're in 12th gear, roughly 1400 rpm and up, the transmission acts like it is trying to shift up another gear, when there isn't anymore gears to go. And when it does that, the rpm dial goes up higher in rpm, rather than lower, like how it would shift normally between gears. All other gears work fine. One code popped up as I was driving. P107492: Gears 2 and 3 engagement system - incorrect performance or operation.
Edited by Hunter013
https://www.bigmacktrucks.com/topic/72745-mack-gu813-code-p107492/
  • Hunter013 changed the title to Mack GU813 Code P107492
  • 6 months later...
  • 6 months later...
8 hours ago, Jayphee said:
I am having the same issue with my transmission, it is disengaging on 6th and 12th gear. Is there someone that can reshare the bulletin mentioned above? Thanks.
I'll repost it, here you go. I don't know enough about the technical side of the mDrive to give any further advice other than the ribbon harnesses go bad a lot. If you're looking for it in Impact, it's called the Passthrough Kit.
Mdrive F GU series.pdf
  • Thanks 1
