1952 Mack l85 . I have rebuilt carb. New fuel pump with 4lbs at carb. Good fuel. Still breaks up when throttling up. New plugs,wires, points etc . Is there a timing advance in distributors. Maybe it’s stuck. I know there is no vacuum lines to them so how do they operate. Anyone have a clue?
https://www.bigmacktrucks.com/topic/72794-timing-advance-on-707b/
are you running on both sets of ignition system ? try 1 set and the the #2 set.   which runs smoother ? I run my Mack fire truck usually on both. Also I install electronics in the distributors ,If you ever decide to do that you have to use a positive ground unit ,no big deal. never have to set points again. I used Petronic brand.
   Also is your fuel good?
Had dynamic carb in Mount Vernon ny. He’s old school guy that does a lot of old and rare carbs. My fuel is fresh, good pressure. I’m wondering if my advance weights are stuck in distributor. It idles great but starts breaking up when you get into pedal
  • 7 months later...
