New here, picked up a 91 ch613 gold dog,  shes old and shes grumpy lol so comin down off from hi range to low range it grinds into position, i was reading something about taking airlines off and sprayin a little wd40 in or something about a nut that comes loose on the forks or something. Common issue from what im reading. Any thoughts???
https://www.bigmacktrucks.com/topic/72812-91-maxitorque-trans-issues/
Check the yoke bolt for tightness! And yes you can remove the rear lid and check the range bolt as well however it is a sign the range pack is failing!
Ok ill start there, maybe its not too bad….yet lol
now be careful when you call a'91 OLD AND GRUMPY!! . wish I was in the '91 bracket=NO not age ; all though getting closer. the '91 bracket is called mid life crisis Mack. my  class (B models) are old and grumpy. getting back on topic= you came to right place for info. i've learned much here.
  • Haha 1
Hahaha well this one isnt that old then🤣
7 minutes ago, Joey Mack said:
it is stamped in the side of the main box, rear of the fill plug..  It is probably filled with dirt..  a wire brush should get it done..
ok sweet ill have a look in a bit here thanks
