don't replace if the copper pipe is all OK ...probly gone hard n brittle
Remove copper pipe with out destroying the shape and anneal the pipe to make it soft again
refit pipe and the jpbs done with out buyin all new fittings to suit plastic/nylon  pipe sheite
WotSezU?
cya
Parker sells fittings for old style cooper tubes too. And new tubes could be purchased in a home store. General use is air conditioning I belive. Those you my use in a truck sell in a coil. Straight portions are hard and don't allow to be bent the way you need.
