I have a 2004 Mack Granite I got recently with the 427 and Mack transmission. For the life of me, I cannot downshift it. It upshifts totally fine, but it will not downshift. Other people have tried and cannot get it to downshift. It only grinds. Sometime it can be forced to downshift, but will grind the whole time.
Tried it all different ways, speeds, etc. It just will not downshift.
What could be wrong with the transmission m ? I think something is wrong with it. Considering swapping for an 8LL...
https://www.bigmacktrucks.com/topic/72903-maxitorque-wont-downshift/
I'm assuming that's a manual Maxitorque, not an automatic?
Got a video so we can see and hear it?
Tried "floating" it, without using the clutch?
Trying to think of what could be wrong that would allow the sliding rings to engage on an upshift and not on a downshift.  I'm drawing a blank.  If a fork or rod was binding, it would not act like that.  Bad bearings?  Seems like it would do the same thing on an upshift.
I mean, if it will move to a place where it will grind, it should be as simple as matching the RPMs, and it should fall in.
Maybe The Brain Trust can come up with something.  Wish it was next-door so I could see it.
So let's try to get some more detail
When you say it wont down shift
Are we talking it wont split the gears, as in the air shift part of down shifting ?
Or it wont allow the gear stick to shift into lower gears, as in change down manually between by shifting the stick
Or is it both of these can not be performed
Or maybe the range change is the issue
I gather this is a 18 speed Mack ?
If so, from what I understand these are built along the same line as any other Mack transmission, just more refined
A main transmission with the range change and split been seperate section bolted on, two seperate gear boxes close coupled
It would be highly unlikely that all sections have failed at the same time
So if you  can establish which gears aren't down shifting it can help establish what part of the transmission has the issue or if it is the transmission at all
So is it the splitter on the side of the stick
The range change on the front
The stick it self
Or a combination of two or more of these
Paul
That was my next question too. Exactly what trans do you have and which shift exactly?
I know these guys can figure it out…with enough information.
Sounds like a process of elimination
if you cruising along can u take the stik out of gear as in nuetral
let the engine go to idle revs
then rev upto the same revs as when U hit neutral
and the gear stik should slide back in to the same cog
no need for clutch on this proceedure
cya
  • 1 year later...
Im having the same issue.  04 mack granite cv713 Mack manual 10 speed trans.  Fresh Waller reman trans.
It will shift just fine from low to high while driving, shifting thru all the gears.  Downshifting is not so smooth.  It will downshift from gear to gear fine, but from 5 - 4 (high to low)  it will most of the times make a loud clunk.  If I let the engine rpm get below 1000, and kick it out of gear, then hit the high to low, it will be smooth.  Or below 5 mph.
Does this sound like a bad synchronizer?  or is there a shift fork may be bad?
there is a small shaft that operates the range shuttle valve.. in the olden days you didnt pre-select the range, you would go to 'N' then range shift.  then shift the lever normal way. ( I am a Double Clutcher) .. this set up allows pre-selection, and when the shift rails ar in 'N' the shuttle valve sends air to the rang shift cylinder.  Long winded, I know, but this info may help.  if the 'rod' is not functionung right, you likely will 'clash' the gears upon range shift..
I have had a bit of teflon tape (thread tape) almost completely block a fitting and cause issues
Or even thread sealant dribble a bit
If this is a issues after having put the box maybe a check a few of these things first
Paul
So, take this with a grain of salt, but we've had issues with Weller recently. BIG issues. Brand new Allison remans failing internally and contaminating the engine coolant with ATF, brand new mDrive components that lasted not even a month, all to the point our service department uses them as a last result. You might have suffered an issue similar to us...
