NO Teflon Tape on any Hydraulic fittings..  Gasoila brush-on or Permatex brush on..   Tape is good, In it's world, but not here.  if a piece of it cuts loose or blocks flow,,, you Will! have a problem..  I brush PTF sealer on and wipe the excess off and It's good to go
https://www.bigmacktrucks.com/topic/72914-teflon-tape-usage/#findComment-532423
I rarely use tefoln tape except for plumbing in the house
I have had tiny bits break of and block airlines and get in fuel lines
Hydraulic oil corrodes it and it begins to leak a long time later
I rate it about aa good as silicone or those form a gasket types
Thread sealant, the none hardening type, loctite is my preferred brand is all I use these days
Use proper thing for the job, to many sure cuts and "she'll be right" type of thinking have come back to haunt me over the years, I think that's called life experience 😆
Paul
https://www.bigmacktrucks.com/topic/72914-teflon-tape-usage/#findComment-532430
Yes Mark I know.. I was just trying to appeal to the young'ns..   Actually...  I need to buy a bottle and brush it on some metal to see how it does again..  I remember it being a B!tch to scrape off..   But not as bad as an E-6 Pan Gasket...
  • Haha 1
https://www.bigmacktrucks.com/topic/72914-teflon-tape-usage/#findComment-532477
This fuel line fitting has a cable-operated shutoff valve.The lever on it has to end up more  or less in line w/ the cable that pulls it when the fitting is fully tight.I thought if it`s way off,I could use the tape to adjust it to where it should be when tight.
https://www.bigmacktrucks.com/topic/72914-teflon-tape-usage/#findComment-532495
