7 minutes ago, Joey Mack said:
The fuse panel in the cab, right side
Another place you can look here is the Vecu check the plug to this its under the  mid dash and unfortunately its mounted wire side up and if the windshield leaks it can cause gremlins if water gets into the plug or The ecu itself!
https://www.bigmacktrucks.com/topic/72930-3-4-code-e7/page/2/#findComment-547469
1 hour ago, HarryBiron093 said:
That’s a great idea I will check the vecu tomorrow. I do remember there being dampness on the passengers side floor so I will see if I can replicate the symptoms.
The fuel pedal has a close relationship with this also !
https://www.bigmacktrucks.com/topic/72930-3-4-code-e7/page/2/#findComment-547484
  • 3 weeks later...
