Engine is a full mechanical E7 350. It is running a bit ruff with a bit of vibration.
  I cracked the injector lines at each delivery valve on the pump. I did not find a dead or non reactive cylinder but what I did notice is air bubbles coming out with the fuel when cracked open a bit ?
  Not sure but I don’t think I should be getting air bubbles. The truck will start ok after sitting for a week so I don’t think it’s sucking air.
Thanks
https://www.bigmacktrucks.com/topic/73057-bosh-p7100-air-bubbles/
Clear plastic lines on the inlet and return fuel lines is the best way to check for air intrusion. When you crack a line it could be sucking some air in with the loose fitting making it look like bubbles since diesel kind of acts like bubble soap. Best of luck!
May sound stupid, but I am trying to figure out how I can add in a clear line on the suction side. I am guessing the same for the return line. As far as I know the only return I have goes back to the pump.  Great idea. I just need to figure out how to make it happen.    Thanks
maybe get some J.I.C. fittings that fit the lines,  #8 I think, with male threads on the other end, and then go to Lowes/ Home Depot,, to the plumping section and look at their rolled hose options.  I like your idea......
Edited by Joey Mack
Pour sperring
