2000 CL 713 Mack 18 speed transmission, 150,000 miles. Driver is saying it is popping out of gear in low range. Shifter is still in the hole, high range is fine. Some people think it is an air pressure issue, others say something might be bent. Has anyone else dealt with something like this? Any thoughts would be appreciated. Thanks
https://www.bigmacktrucks.com/topic/73061-mack-18-speed/
If it was a 12 speed I would day there's crud built up in the low range gear were sliding dog goes in
I know nothing about 18 speed Mack boxes but feel something similar could be a issue
Does this box have a PTO fitted ?
Has it had any work done on it  ?
A few more details here may help people point you in the right direction
Paul
https://www.bigmacktrucks.com/topic/73061-mack-18-speed/#findComment-535130
Original owner. Yes it does have a PTO, its a dump truck, I had a clutch replaced 10,000 miles ago. Obviously not an everyday driver, so crud build up could be an issue. Is there typically an access or plan on taking the tranny out?
https://www.bigmacktrucks.com/topic/73061-mack-18-speed/#findComment-535131
Cl713 likly has a Cummins in it! Check the rear output yoke for tightness! These were quite an issue behind the Cummins ! If it’s tight remove the top rear shift lid and check the shift fork bolt ! If it’s tight then the back section of the trans may have to com off and neew synchro plates installed!
https://www.bigmacktrucks.com/topic/73061-mack-18-speed/#findComment-535132
Nice my favourite! Model bar none for a dump truck !stand up oil change!😂It’s best to pull the transmission hatch if the box controls haven’t been mounted over it you might get lucky most box guys don’t consider that someone may have to pull the transmission some day! The trans can stay in the truck to do the back section but likely have to go to the dealer to have it done! Still check the yoke bolt and fork bolt also answer joes question there that is important too for proper diagnostics!
https://www.bigmacktrucks.com/topic/73061-mack-18-speed/#findComment-535136
My 10 speed t310m had a similar issue, shift fork was very worn also in conjunction with worn synchro gear ...I took the rear cover off and welded the shift fork up and grinded it down to size..this quick fix got me through the busy summer..then rebuilt the whole transmission..like FJH mentioned,the rear part can be removed but will need a specialty bracket to hold the 3 shafts in place...if truck is new to you ,I would remove transmission completely and have it gone through....main boxes are kinda bulletproof, synchros are the Achilles heels.
Just my .02 cents
RED
https://www.bigmacktrucks.com/topic/73061-mack-18-speed/#findComment-535362
Just my .02 cents
RED
Yup to avoid buying tools pull it stand it up on a wheel rim of the appropriate size or two 6x6 wooden blocks and pop the back cover ! Recommend checking the rear bearings on the main case while you’re there how ever not nessary just a precaution!
https://www.bigmacktrucks.com/topic/73061-mack-18-speed/#findComment-535368
Just my .02 cents
RED
My 12 speed was built up with bronze when I got it and it has done many many 100's of 1000's of miles since and it is still fine
I think it was a attempt to stop the range change jumping out of gear
Gears were badly worn, I replaced the gears and sliding dog and it has never been a issue since
Paul
https://www.bigmacktrucks.com/topic/73061-mack-18-speed/#findComment-535478
