Oil Bath Air Cleaner
Go to solution Solved by Geoff Weeks,
I've never filled one of these caps before...it says to fill it up to the bead. I assume you fill the entire bottom cup? Once you get it up to the bead it starts to trickle over into the center area. It takes like 2 quarts to fill the whole thing!
